data curruption error
billkater
by billkater » Mon Apr 25, 2016 2:08 pm
I have gotten 2 data curruption errors. I am guessing i have a hard drive failing. I have a ssd drive as my boot drive and my programs installed on it. I have a sata drive as my storage drive for my video. Which drive would be suspect to be failing? If it is the storage drive, should u replace it with a NVR drive like Western Digital Purple WD30PURX 3 TB?
Thanks
Bill
Re: data curruption error
by Devin » Fri Apr 29, 2016 10:04 pm
Hi Bill,
It sounds like the drive that is failing is likely the ssd. If the drive containing the video location was failing you would see frequent messages asking you to locate the "archive" folder. I'd be happy to take a look at your logs if you could submit a bug report by going to Help > Report a Problem. Be sure to include a link to this post so we know it is you.
billkater
by billkater » Fri Apr 29, 2016 10:15 pm
Thank you. I will do that
